Anyways all you awesome engine builders/tuners out there hit me with some ideas:) (esp you Dee)
Thanks guys
Sounds like you may have an issue, if you keep seeing the milky residue. The problem with the metal H/G is the fact that your pistons and your head is now the fuse and the will let go before your metal H/G does. First of all, what were you doing that cause the concer? Next, I would check the plugs as they can give you a sign of issues. Also, you have to be careful with metal gaskets because torquing them is a bit tricky and requires you torque them twice and leave it be for a little while and then re-torque. Check the compression and we'll take it from there. If one cylinder is considerably lower than the others, be prepared to face a melted piston or a piston with damaged ring lands.ganma_ca wrote:Ok so please don't be too pissed off to those of you who are offended by basic engine questions. I am looking for some answers from the likes of the engine Guru's..... Ok so I think I had a blown headgasket, sorta, like no smoke from the exhaust but a milky white substance on the oil cap, which would be typical of oil/coolant mix. Car holds boost solid, but also notice slight "pinging" even after adding some supposed "octane booster" Like when I listen at the exhaust tip I can ever so often hear a ping or even a slight misfire possibly. I need to drain the oil and coolant and see if any are mixed? Or do a compression test? I'm just like wtf it makes no sense. The engine has a multi layer metal headgasket and I won't rule failure out, but dang it's not a composite one and a lot harder to destroy. So guys any ideas??? I had a few but they are kinda unfounded. I thought hey this car was always garaged. I live in Colorado and the nights see temps as low as 10* or even less and I'm wondering possibly if some shrinkage happened with all this metal and allowed some coolant into the oil, but then with summer being here and the metal being expanded head gasket leak/blown problem solved?????? Idk![]()
Anyways all you awesome engine builders/tuners out there hit me with some ideas:) (esp you Dee)![]()
Thanks guys
