fitch9014 »
https://forums.nicoclub.com/fitch9014-u32378.html
Fri Jan 12, 2007 6:22 pm
i've spent the last 4 months messing with engine management options, funky knob turning, rearranging gauges, upening the boost, lowering the boost, considered selling the car for an rb20 swap, finally installing an adjustable fpr and a fairly decent a/f gauge. that **** took forever, then fixing the constant fuel leaks from my riggend fuel lines (i think i've finally got that one, even though the car still smells like high test and the apple air freshener turned black), then, most assuredly at 1 bar, whacking the piss out of the fuel cut in two gears...if you haven't felt that one, i suggest you try it, it's an experience your likely not to forget. but most importantly, realizing that over the past year and change i haven't learned more, met more people that are as interesting, tried more and made more half assed attempts at automotive tomfoolery than i have before this. this motor and car is mine!!!! and i'll finish it, sort of, eventually. right now, i'm thinking i should probably install that fcd that's been in my door holder forever and a stronger clutch (stay away from spec stage 1 clutches, they smell like poo when they burn!)
p.s. i've seen what appear to be quite a few new ca peoples and that's good, but you've got to be paitent, this **** doesn't happen overnight, it took me six months to get mine running, partly because i didn't know what i was doing and mostly because i'm lazy. this motor set is fantastic and there's a lot of good info in here...oh, and follow float6969's upgrade guide, it'd have been nice to see that before i wandered in and out of concisousness(sic) and then pissed so much money down thedrain ...but, oh well, better late than never...
p.p.s. INSTALL THE ADJUSTABLE FPR BEFORE YOU INSTALL THE ENGINE IN THE CAR!
