CA KNOCK SENSOR
MikeDombeck
Car: 1995 Nissan 240sx SE S15 SR20DET
ok, so i changed the knock sensor, and it is still flashing knock sensor. I herd that some SR ecus have the 02 sensor pin in different spots, is it possable that any CA ECU's have different locations for different pins on differnet ECU's?
jt15833
Car: 95' 240SX
you wired with sheilded wire to 23? althought non sheilded probably wouldnt throw a code just throw off readings..
MikeDombeck
it
jt15833 wrote:you wired with sheilded wire to 23? althought non sheilded probably wouldnt throw a code just throw off readings..
it is shielded
damesta
Did you reset the ecu?
sideways danny
Car: s13, CA18DET
knocj=k sensor is notoriously crap, as is the wiring loom to it, It's getting more common for people to wire a resistor in to trick the ecu I'll try to find the link on sxoc
MikeDombeck
sideways danny wrote:knocj=k sensor is notoriously crap, as is the wiring loom to it, It's getting more common for people to wire a resistor in to trick the ecu I'll try to find the link on sxoc
ive been looking for what u were talking about with no luck, how about you. did u find it yet?
float_6969
did you wire it up directly to the ECU or though the harness? Some people have had problems doing it through the harness. Also, when you check the codes, it clears them out when you back out. If you check them, back out (turn the screw) and then turn off the car, turn it back on and start it, let it run for a couple of min, and then recheck the codes, you'll get a more accurate gauge of what is actually going on.
MikeDombeck
float_6969 wrote:did you wire it up directly to the ECU or though the harness? Some people have had problems doing it through the harness. Also, when you check the codes, it clears them out when you back out. If you check them, back out (turn the screw) and then turn off the car, turn it back on and start it, let it run for a couple of min, and then recheck the codes, you'll get a more accurate gauge of what is actually going on.
ive never herd of that before, and its tru the harness, i will put it thru the firewall to see if it is different.
sideways danny
Car: s13, CA18DET
http://driftworks.com/forum/sh...pp=20
this was on an RB25 but same theory
MikeDombeck
i ran a new wire and the code is gone, so it was in the harness, also:: it still runs weird, so it wasnt that in the first place
float_6969
Check for vac/boost leaks. MAFS systems don't like leaks, even small ones.
MikeDombeck
float_6969 wrote:Check for vac/boost leaks. MAFS systems don't like leaks, even small ones.
HOLY SIDEMOUNT!!! i dumped my hose in my sidemount, and it came out just as fast as it went into the thing!!!! gayness galore.
