Before you swap in the engine I would do a new water pump, t-stat, timing belt, head gasket, and studs. A walbro fuel pump is also a good idea.To meat your power goals. A T28 should get you 300 flywheel easy. Some say you don't need to do injectors (but it is a good idea). Do an ECU tune also. I would think it's easier than SR. The only reason I can think of is the radiator piping is the same (you can use the stock KA radiator).iheartu wrote:I currently have a s14 and was thinking about swapping a Ca in it because its something different and are cheap motors compared to the sr20.
I looked at the stickies and found some good info but I have a couple questions on things I could not find. 1) What are some common problems I will face due to the engine being old?2) What are some parts that should be changed before I swap the motor in?3) I am looking to get around 250-300hp. What are some things that should be done to achieve the hp goal? 4) Is the swap harder to do on an s14 than s13?
Thanks for the help and looking forward to seeing what you Ca people have to say!!!
What would be a ballpark price on the rebuild? It would just be a stock rebuild. Also what online shop sells Ca's that are in good condition.themadscientist wrote:do a complete rebuild. The motor is old, it needs one guaranteed.
where did you find a s15 sr for that much? I cant seem to find them under $2000.Two-Fortee wrote:ok, for the average guy on some kind of budget, a rebuild is out of the question. There is no use in spending $1500 on a rebuild when the motor costs you just as much. **** it, you can get an s15 SR or almost an rb26 set up for that much. Find a responsible dealer in your area and try and get a warrenty. Most people swapping a ca18 dont put more than 10 000 kms/miles on there car a year, so im sure its going to hold up. Im not stopping you from a rebuild, but I guess this is just coming from a guy who works very hard just to keep his car on the road and trying to hit some decent numbers. Anyway, good luck with your "build" weather it be a rebuild or not.
I can't disagree more. If you cannot afford a rebuild or a failure do not pass go. I am getting so tired of seeing people spend every cent they have scraped together just to get the motor and then when something fails, turbo, head gasket, etc they are tapped out and left with a lawn ornament.Two-Fortee wrote:ok, for the average guy on some kind of budget, a rebuild is out of the question. There is no use in spending $1500 on a rebuild when the motor costs you just as much. **** it, you can get an s15 SR or almost an rb26 set up for that much. Find a responsible dealer in your area and try and get a warrenty. Most people swapping a ca18 dont put more than 10 000 kms/miles on there car a year, so im sure its going to hold up. Im not stopping you from a rebuild, but I guess this is just coming from a guy who works very hard just to keep his car on the road and trying to hit some decent numbers. Anyway, good luck with your "build" weather it be a rebuild or not.
I hear that! I just bought a '93 S10 with almost 200k, but I got it super cheap. Changed all fluids (less diffs) and am planning on running it that way as a backup vehicle. Not beating on it though. I'm sure I still haven't seen any RPM past 2.5k.themadscientist wrote:
IF YOU CAN"T AFFORD TO DO IT RIGHT LEAVE IT THE HELL ALONE!
You are dealing with a 19 year old motor people! Would you pull an engine out of an 89' chevy or ford and expect to drop it in untouched and beat on it with no failure?
Why buy any engine at all? If you desire to have a CA18 you have to buy a 20 year old engine. If you buy a 20 year old engine 9 times out of 10 it will need a rebuild if you expect it to perform. An S13 with 45000KM on it is not common and even if the kilometers are low if it was improperly maintained it is not in good shape. My 150000KM CA18 was running great up until I pushed the boost past my fueal system's capability and popped the head gasket. This engine was religously maintaned by me for half it's life though. Most of these motors are sourced from junkyards and are in dubious condition. You take a risk with them and to assume the dice are going to roll in your favor when you go all in is a dangerous gamble and odds are you are going to get burned.Two-Fortee wrote:Maybe its because I drive a 180sx with 45 000 original kms on it. The last thing I'm worried about is blowing the engine. Yes, extra cash is always good, but why the ****, would you buy a 20 year old engine just to rebuild the thing.Peace.
