float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sun Oct 19, 2003 2:26 pm
Ok, so here's the deal. I had to pull my manifold because it was COMPLETELY coated in oil. I'm assuming this motor spent alot of time in the high RPM's or had a bad PCV valve. Regardless, I had to pull it and clean it out. So so here is my question;
For the valves on the secondary manifold, the actuator is run on a vaccum and the valves are normally open. Does the actuator computer controlled, or just manifold pressure based? I think it's manifold based, but I'm not sure. What I really need to know is this;
At what points during the RPM range is the manifold under vaccum or pressure. I would think at the lower RPMS befor the turbo spools, the manifold would be under a vaccum, which is when you would want the valves to close so that you would have better torque. Once the turbo spooled, the manifold would be under pressure and the valves would open. If I'm way off, please let me know. Thanks!
