ks13 wrote:you will yield more peak power with a tubular manifold, but more area under the curve is attainable with the stock manifold. more area under the curve is what you want unless you are circuit racing.
I'm quite aware of this. I feel like you're missing my point. I never said to get an equal length tubular manifold that wasn't paired. In fact, I would strongly suggest staying with a paired manifold, and even better, a twin scroll turbine housing. (this is what I've done with my turbo setup, and I'm running a T4 turbine). My point is that to get to 400whp, and to try and move that much exhaust through a T2 flange is going to be limiting. It's do-able, but not the most efficient way of doing it. AND, AFAIK, you can't get a twin scroll turbine housing in ANYTHING with a T2 flange. It's because the flange is so small, that adding a divider cuts the area down so badly that it wouldn't be able to flow much exhaust, which would limit it's peak horsepower. I understand that area under the curve is very important. But only to a certain extent and to what application? He's autoXing, so he does need as much power band as possible. This means bottom end AND top end. That T2 flange is going to choke out at 400whp. That's a simple fact. He could get the same bottom end response, and increased top end power, from a T3/T4 hybrid, and get a fully divided exhaust setup (manifold AND turbine housing), which would ultimately yield him more area under the curve than what he would get from staying with the stock manifold and going to another T2 flanged turbo with a single scroll housing.
bobs1200ca wrote:thanks for the imput guys, Here are my starting plans wiseco pistons with k1 rods, lightened crank, chrome molly flywheel arp head studs and main bolts rods already come with arp bolts, tubular exhuast manifold with top mount turbo clean up of ports in head titaium valves and retainers upgraded valve springs. intake, turbo size, injectors yet to be determind. not sure on ecu yet but will be speed density system with stand alone. I am familiar with having apeaky engine 1400 i have in car now is fully built it has 145 at wheels and car weighs 1400lbs with ca car will need to be around 1750lbs
http://datsun1200.com/modules/myalbum/p ... ?lid=21443
Stay away from the Wiseco pistons. Due to their design, they can't accommodate the piston oil squirters that are in the block. I would recommend CP pistons. Myself and many others use them and have great experience.
You don't need rods for the power level you're at. Put some ARP rod bolts in the stock rods and you'll be fine to 500HP.
Make sure the exhaust manifold is a divided manifold and that you pair it with a twin scroll turbine housing. TRUST ME, you'll be glad you did. I swapped from a single scroll, to a twin scroll housing and it made a huge difference. Not only does it spool faster, but the transient response is WAY better. Pair that with a new BB center section and your response would be nearly instantaneous, which is obviously something you want in AutoX.
You've mentioned it, but do pay attention to the ports. There is a lot of power to be had porting the head.
If you design this right, it won't be peaky at all. I'm in the same power range as you, running a small T4 turbo, and I'm fully spooled by 4K. I was running up to 8K with my T28 and stock cams. With the bigger turbo and HKS cams, I'm expecting to be able to go even higher. If done right, this engine doesn't have to be peaky.
