CA + HICAS question
alfred183
So, uh, yeah...me and Mikie's clips had HICAS and there's two places to attach power steering lines on the pump...is it safe to just plug one up and pretend like everything is ok? or will this hurt something? Do SR people have this issue as well?
Dammit! Why didn't Sport Compact hold my hand through this??!
Am I gonna need to get a new pump?? Which one is compatible in the US?
NeedCAforS13
Car: CA swapped S13 coupe
you need a new pump...do NOT plug one hole and just use it... Paul's SR motor had the same deal...hicas pump on a non-hicas car...your only option is to find a new p/s pump (non-hicas of course!):D
Sean
Nismo1182
Car: Z06
I have a hicas pump on mine and I did what Paul did. Use the first hole for the power steering.
Take the pump out before you do anything, remove the back housing. (should be 4 bolts) Once you open it, you will see little fins. They come out easy by hand, so remove them all. Put the back housing back on. Find a bolt to plug up the 2nd PS hole, put teflon on it incase it leaks.
Now the pump should be good to go. I have no problems other than the connection where the small hose coming from the resevoir turns into a big one for the pump. It leaks there but thats my ghetto connetion reducer type thing I have.
NeedCAforS13
lol, i didn't know you guys ghetto rigged it! so nevermind alfred, I don't know what I'm talking about:D
Sean
CA19DET
i plugged the hole pn my hicas pump and allot of high presure steering fluid went all over the place, casuing belts to squeal and howl like a banshee, along with the dramatic cloud of smoke too of course when it was burned by the manifold and turbo ;)
Nismo1182
Car: Z06
CA19DET wrote:i plugged the hole pn my hicas pump and allot of high presure steering fluid went all over the place, casuing belts to squeal and howl like a banshee, along with the dramatic cloud of smoke too of course when it was burned by the manifold and turbo ;)
Thats why me and paul removed the fins from the back housing ;)
Pressure builds up back there with the fins in place.
CA19DET
i know i was just sharing battle stories... it was funny though leaving the shop for the first time with teh CA18 in the Capri, going down the road grinning only to see smoke and hear squealing, pop hte hood and see red fluid everywhree...
OMG!!!
hehe, you live and learn
Mikie
Car: Cars/Music/Bands/Women/Carousing/hunting/offfroading/fishing/racing/strippers
How about the resevoir? which one would I plug? or does it matter?
Nismo1182
Car: Z06
The Hicas resevoir uses a bigger hose going to the pump.
I used my KA resevoir and made an adapter in between the little hose and the big one.
mattlord42
Car: 1991 240SX Coupe
Hey-
As I recall you guys both got your clips from Venus right? The CA clip that we got from them was also HICAS. All we had to do was call them and complain and they told us just to find a non HICAS one and they would reimburse us for the full cost including shipping. We got a non-HICAS one from themadscientist. So that is an option to the ghetto rigging method.
Matt
PS please just ignore this post if you didn't get them from Venus... I am pretty drunk right now and don't clearly remember everything...
