Hillkill wrote:I'm having the same problem. When I start her and give it some gas the idle drops and sounds like it's about to die. Once she's a little warm she runs fine but every 30 seconds to 5 min she will sputter and backfire like she is going to die. Sometimes I give it gas and it misfires heavily. Gotta figure out the problem.
This sounds like some sort of ignition problem. Check out the ignitor.
zil40 wrote:checked all of the charge pipes and couplers it doesn't appear to have a boost leak, unless the stock sr intercooler is leaking (cracked from shipping or something weird like that.) the car starts fine idles fine. but the moment you crack the throttle plate it goes to 5" to 0" of manifold vac. and bogs really bad and tries to die. as it gradually warms up it seems to get a little better w/ throttle input. it still never runs right when its warmed up. you can just slowly give it more throttle. once it boosts it runs and revs fine. but off boost it sputtters. when cold it is way worse that when it starts to warm up. one question, does the jdm and euro ca's have diff. maf sensors? our harness is 4 wire. our maf is "4 pin 3 wire" it has provisions for four wires but the "A" pin is factory molded blocked off. is the jdm ca supposed to have a 4 wire maf?
First of all my car pulls about 38cm/Hg at idle. That equates to almost 15in/Hg. If you're only pulling 5in/Hg at idle, you've got a pretty good boost leak in the manifold somewhere. Possible sources are;TB Gasket (includes the plate on the back of the mani)The idle control crapBOTH intake manifold gasketsAny/All of the injector O-rings
I would also think that the car is idling pretty high.
As I said before, the fact that it runs fine under boost tells me it's a leak of some sort. The car runs lean under Vac and Rich under boost w/a MAFS system.
The lean condition could be causing your poor idle. It sounds to me like the problem is in the intake manifold somewhere
As far as the SOHC MAFS, it should work fine. The difference between the two is negligible.
