here's mine with a set of high compression pistons and a copper sprayed stock headgasket. Kinda hard to see... your DET pistons should look about the same, but flat in the middle instead of domedOguraPowerTuning wrote:does anyone have a picture like the one i took so i can see stock stuff
I don't think it's blown unless the ring around the circumference of the gasket is burned. If you were missing compression and the gasket haven't been burned, suspect the pistons to have cracked ring lands.OguraPowerTuning wrote:what material is a stock ca headgasket made from? im rebuilding a ca right now and it has a silver-metal head gasket(blown). i didnt know if ca's had paper type gaskets like sr's or if it came stock with the metal one i have. [IMG][/IMG]
Tells me that you may have blown ring lands and/or worn engine/rings and pistons. That compression is pretty low on some othewrwise stock pistons. A real blown headgasket will give you almost no compression on those cylinders, so suspect a warped (like you said) as well. But defintely check the pistons as it won't kill you and you will be surprised at what you find.OguraPowerTuning wrote:look at the pick see the oil between the two cylinders on the headgasket. that tells me that pressure can travel between the two cylinders between the head and the block. im checking the head tomarrow to see if it is warped and here is a pic of my piston, i cleaned the carbon off of one for a pic.oh and the compression on the motor before i broke it down was 120,120,60,60
come on guys can you help me out with thisOguraPowerTuning wrote:i took the head to the machine shop today. it was absolutly not warped and the head gasket looked pretty good so im going to check the pistons now like you guys said. i need to know where to get the cheapest aftermarket pistons for this motor. im only looking for 300hp max so i dont need to much fancy stuff. and i also need a compleat engine gasket and seal kit, how do i get this. maybe an 85 200sx? or do i need a det gasket kit. i abslolutly have to have valve seals and cam seals.
The only place in the US that I know of to get aftermarket pistons for the CA is from Race Engineering. http://www.raceeng.com Item number- XTP-553P835OguraPowerTuning wrote:come on guys can you help me out with this
Bro, you really don't need forged pistons for a mere 300hp. You need to focus on those things that will accomodate you in this quest such as a better turbocharger, better or upgraded engine management system and an open mind to know that things don't always go the way as planned. As for your engine/mechanical/physical, clean up the stockers or replace them with good stockers if applicable (them meaning pistons, rods, rings). But if you absolutely must have forged pistons, be sure and have the fuel system upgraded immediately.OguraPowerTuning wrote:this motor was in pretty bad shape i think a japanese woman drove it because the oil wasnt changed properly and the coolent wast changed properly. i took the water pump off and it had a rust mud goo in it i bet it didnt flow at all. if i can get a piston set with rings and pins for under 700 im going with it. how will my stock rods hold up though. this motor needs to be tough because my wife is going to drive it some and she is a japanese woman who is very rough on cars.
My patent 5-step solution to pressurized vacuum lines:float_6969 wrote:the wastegate line blew off.
Or... just get some hairspray and spray it on the fitting before you slide the vacuum hose over it. Works everytime and they will NOT blow off.biosehnsucht wrote:My patent 5-step solution to pressurized vacuum lines:
1. Go to junkyard.2. Find a turbo DSM.3. Steal many vacuum line clamps.4. Install vacuum line clamps on your car.5. Drive the piss out of it, like you normally do.
