Ca getting installed now need some info
kim
Car: 90 240sx, 97 M3
I'm getting ready to lower the engine into the car needed some quick questions answered.
1. Does the lower heatsheild for the turbo need to be removed? I'm putting an SR elbow in so I'll leave it off if it rubs against the steering shaft.
2. I thought that the stock intercooler comes with a bypass valve. The intercooler I got just has 2 pipes for inlet and outlet. I don't see any bypass device do I need a blow-off valve? If so I'll order one right away.
Thanks in advance,kim
WeldingHank
Car: 1989 240sx CA18DET
1. the lower heat shield needs removal.
2. the CA did not come with a stock by-pass. it would be in your turbo's favor to buy one, but if you keep the boost low, it won't be a problem.
kim
Thanks for the answers but I have another question on the batch of wires that with the Gray connector and Brown Connector that needs modifing there are some other connections one of them the connector was ripped off or something so I don't know what use for could anybody tell me:
1. what is connection made to:
2. What are they for?
Picture below:
rico05
Car: 1992 RMS13 w/ CA18DET
Mine aren't connected.
