DeXteR »
https://forums.nicoclub.com/dexter-u32945.html
Fri Sep 21, 2007 2:30 am
first, i'm not sure about the differences in clutches. when i had the ka engine out of my vert, i should have checked the flywheel against the ca just to see those differences. i do not have a ca clutch or pressure plate, so i couldn't tell you from first hand experience.
to address your second question: are talking about the automatic ka transmission? not being a real transmission expert, i'm not exactly sure what all the switches are for. on my 5-speed swap, the only sensors i have hooked up are the speed sensor and... soemthing else. it seems to be fine.
hopefully someone with a little more experience and knowledge will chime in here.
