ca18datsun510 wrote:
all the write ups on using the sr flywheel/clutch clearly state to use a hoodless, gear reduction starter from an 86 200sx.
including the write up in the stickies on top of the page that float and others have taken time to write, that no one ever reads.
i was saying no to using the sr starter, not the other stuff.
here is a sr spec blitz on a ca. will work with either ca starter, stock det, or the hoodless
here is a stock sr flywheel, notice you cant see the ring gear? that would be why you need the hoodless s12 starter, the hooded one hits that spot of the flywheel.
AND I WILL SAY IT AGAIN, AND AGAIN, ALL THIS INFO IS AVAILABLE IN THE LINKS LOCATED IN THE STICKIES AT THE TOP OF THE PAGE THAT FLOAT AND OTHERS HAVE WORKED SO HARD TO PUT TOGETHER.
NO ONE EVER READS THEM, THEN POSTS THE SAME QUESTIONS OVER AND OVER AGAIN AND THE THREADS GET FILLED WITH FALSE INFO.
