pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Thu Oct 02, 2003 10:17 am
Well if it burns oil, it could be cause by few things, piston rings are worn out or valve seals, or blown turbo. but you already replaced the turbo, assuming that it is still good.I would do a leak down test and a compression test and see what results comes out.chances that you need to replace the rings.check if your car smokes first thing when you start it in the morning, if it does. valve seals are gone.
I hope that helps,
PULSAR GTR
