CA easy maintenance??
cosmo
I've been researching the CA, and more than one person has commented on it being really easy to work on? Is this true? Is it harder or easier to work on than the KA or the SR?
Everyday, I start leaning more and more towards getting a CA. Can't wait till I get some denero
Nismo1182
Car: Z06
so far it seems about the same as my ka to work on. But ive only had the engine for about 2 weeks. Havent done anything major short of dropping the engine in.
slw240sx
Car: 1990 Ca18det 240sx Hatch
if you know what your doing then its easy
Spectre_240sx
Car: 1990 240sx SE
Also depends what type of job you're doing.
USDM_OneVia
Car: Racing
The only thing that I don't like so far is having to carry 3 tools to get to the spark plugs. A 10mm to take off the garnish plate, an 8 mm to undo the coil packs, and a spark plug socket for the plugs.
But other than that, it's all pretty accessible. No worse than the KA. And like Jon said, it is easy if you know what you are doing.
Joe
slw240sx
keep the garnish off them coil packs! heat is your enemy.. and ill check on the actuator now !
USDM_OneVia
Car: Racing
I've taken your advice on that one.... but I am thinking of slotting some vent holes in it. I really do like that trim peice on there though, it kinda completes the package in a way. I am going to see if Kevin can make us up some carbon fiber ones though :)
Joe
USDM_OneVia
Car: Racing
Oh.... btw. It has to be an upgraded actuator. It hits 10-11 pounds when giving it hell. It won't stay at 7 pounds.
If your actuator doesn't work for me, would a MBC limit it to 7 pounds or will it be like we discussed earlier with a 10 pound wastegate setting not knowing what the hell lower boost is?
Joe
slw240sx
if the wastegate actuator is set to open at 10psi then you cant lower the boost too 7 with out a stock actuator, its probably the way they upped the boost on that motor. they would just run 10psi all day.
USDM_OneVia
Car: Racing
Figured....
Guess I am going to have to get that stock actuator from you and keep the boost down.
I blew the intake pipe off twice trying to overtake a car on my "test run" yesterday. Plus it spikes pretty quick and hits that damn boost cut... grrrr :mad:
Joe
Spectre_240sx
Car: 1990 240sx SE
USDM_OneVia wrote:I've taken your advice on that one.... but I am thinking of slotting some vent holes in it. I really do like that trim peice on there though, it kinda completes the package in a way. I am going to see if Kevin can make us up some carbon fiber ones though :)
Joe
hmm, what about some sort of woven mesh finisher? It would let heat escape, but still finish the package.
