biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Sat Oct 15, 2005 5:15 pm
Well at least with everything working as intended
I can put around town under 3k in the lower gears ok but you'll not be winning races there; it's no slug (except under 1k) but let's be realistic, its only 1.8 and not yet on boost (a boost controller would help this, as would me fixing that one leak at the cold start to intake mani hose)
but from ~3k to ~7k it pulls pretty strong yet flatly.. sure with upgrades it would peak more, but as it is while as I'm about to hit redline I'm not making as much power as just abit before it BUT I'm not losing power at such a rate as to feel that I'm slowing down, still being pushed back into the seat (just less so).
and this is stock turbo, but then I do have a host of other goodies (see sig). still need to throw on my RB20 MAF and retune again for that, then hit a dyno. that and I (and most here) still have USDM 4.08 gears, the CA is meant for 4.363 gears which will admittedly narrow the speed to revs range of usablity but the enhanced power output should be worth it, unless you've got a real monster of a car..
but again stock for stock or mod for mod you're not going to get more out of a CA vs SR, as far as #'s go. You could, if upgrading and tuning wisely, be able to get a more useful powerband from a CA than a SR, in part due to the higher redline and ability to survive there repeatedly (and no worries about broken rockers).
