Is there not a U.S. equivalent flywheel and starter I can use?fluent wrote:You will have to use the CA18DET manual starter motor & flywheel
I don't...........I have to use my S12's 5 spd CA18ET transmission anyway, because a ca-det 5 spd transmission is longer which will require hacking on the S12 chasis and custom drive shaft to make it work. A ca-det front clip /w auto transmission is about $700 cheaper than a 5spd clip......so thats the only reason I am considering getting one, but if it is going to be a pain in the arse to find parts to make it work, I'll just get a 5spd clip.I have heard that a ca18et flywheel won't work, because it has less bolt holes than a ca-det...... I do have a ca-et fly wheel, so if it will work, that would be great......can anyone confirm? I did see an aftermarket flywheel listed for a ca-det somewhere for like $250 new.Someone on club s12 has used a ca20 starter on their ca-det project, but I don't think they have cranked it yet...they just said it bolted up.BACARDI_DWB wrote:just wondering why do you want an automatic transmission?
Ahhhh, haaa!! I kenw there was something different between the 2.......i just couldn't remember what. Thanks for clearing that up.2BN_S13 wrote:On the left, CA-ET 6-bolt. On the right, CA-DET 8-bolt.
Not compatible!
So my ca18et starter WILL work then?float_6969 wrote:you have to find a gear reduction, hitachi brand, starter from a CA18ET
