tyrannix »
https://forums.nicoclub.com/tyrannix-u27595.html
Fri Jun 30, 2006 3:02 pm
sounds like your ka driveshaft is missing a piece?
the 'bundle of brackets' on the shaft near the transmission isnt really supposed to come apart.. youre just supposed to unbolt (4 bolts) from teh diff, then the center carrier (2 bolts), then slide it out of the transmission... promptly getting covered with the transmission fluid you forgot to drain first.
go slide the rest of it out of your old KA transmission and rebolt it to the shaft, then knock off the CA dust cover
CJ
