r34 gtr »
https://forums.nicoclub.com/r34-gtr-u3863.html
Mon Jan 12, 2004 1:49 pm
the first 3 dont seem too horrible, not sure what correct specs for the ca are. it looks like number 4 is the problem. hows the head gasket look? it may be starting to go at the back of the engine causing #4 to be low and #3 to be slightly below the others. also, try putting oil in the combustion chambers and running another test, if it goes up, the rings are bad.
i wouldnt go as far as saying you need a new block, even in the worst case scenario you can bore the old one out a little bit and oversize the rings or get some new pistons-which i couldnt imagine costing all that much more than a new block.
i can sympathize, i know how it feels to be in high school and have your car die on you - im in highschool and this car just loooooves to let me down when i need it most. i love it though, ill probably keep it until the day i die.
- tim
