Nismo1182 »
https://forums.nicoclub.com/nismo1182-u2371.html
Wed Mar 10, 2004 9:16 am
Im sure he can unscrew the line to where it goes behind the motor and screw on the CA lines. He will have to use the CA condenser, unless you can unbolt the line there also.
If the clip is a silvia clip, then the PS will good to go. Only problem will be you will need the DOHC KA powersteering line or bend and ghetto rig the SOHC to over to the driverside like I did.
If you have a superhica pump, you have to remove the rear housing and remove the little fins and find a bolt to plug up the rear housing.
