CA 370cc Injectors - Harness Clip
Titan
I just popped CA injectors into the SOHC, and I noticed the harness clip does not match the injector's electrical plug.
I already tried to file a section of the injector plug down, but to no avail.
For anyone who has this particular setup, how did you modify the plug to fit?
uncle_louie83
Car: 1993 Nissan 240sx Coupe
id prolly try a set of clips off a dsm....they might work...ya never know man...as for the right set of clips....there was an old *** version of the sentra's that came with the 1.8 CA18DE engine in them....if you can find one at the wrecking yards then get the clips off one of those...i seen one first hand for the first time the other day at the pick n pull yard....but it wasnt there today..someone took the swap.
lewis
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
There is a tab on the inside and outside you need to remove to make them fit. I used a razor blade to remove them. If you do that they should fit fine. Tight but fine, if they are really CA injectors. Where did you get them.
Titan
LEMHEAD16 wrote:There is a tab on the inside and outside you need to remove to make them fit. I used a razor blade to remove them. If you do that they should fit fine. Tight but fine, if they are really CA injectors. Where did you get them.
I got them from a guy on the CA forums.
Which tabs are you talking about? Remove on both the harness clip and the injector clip?
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
both of them are on the injector
