MeanGreenS13 wrote:been searching around and all i can seem to come up with is people doing a TH400 and a Glide... im not a fan of either trans, the TH400 is retarded heavy, and altho it was used for years on the street, a Power Glide is less than ideal for street driving in my eyes.
The C4 is by far the lightest and it doesnt hurt that ive got a fully built TCI C4 sitting here with manual valve body already.
Im going to kick off my project sometime around april, just trying to gather as much information now, to make everything go smoothly later on. THANKS GUYS!
Phil
I'm not trying to sway you from the C4, because I was in the same boat as you nearly 2 years ago when I started my S14 project. I went with the TH400 over the C4 because of higher power holding potential, lower price, and simplicity of swapping to a glide later. My car sees no street use, so that's ok with me.
As far as the AMS kit goes...
http://www.amsperformance.com/...age=1
This is an adaptor that goes between the Nissan Bell and the Ford Trans much like the BDE kit I use on my car.
However... There is a difference in length between the VH bell and all other Nissan bells of about 1.100". This will cause your Torque Converter spacing to be different on the VH than the KA that AMS is used to supplying parts for. Just something to keep in mind.
Lastly,
http://www.bde-performance.com makes a 4L80E kit now, which would give you an overdrive gear, something neither the C4 or TH400 can offer. It's not on their site, but call and ask Brett about it.
