C200 rear axle shaft
D21hardking
Car: 1991 D21 Hardbody King Cab 2.4L 2wd
1997 D21 Hardbody XE King cab 2wd 2.4L
This may sound like a crazy idea, but here it is. Does anyone know if there is a 5 lug axle shaft option that will fit a C200 diff in my 97 D21?
I've been thinking of changing to a 5 lug hub due to a lack of nice rims available for the old 6x5.5 pattern. I'm trying to cheat a bit and only replace the shafts if possible. If not,may have to invest in a rear diff.
Any help on shaft specs would help too. Thanks ! :werd:
D21hardking
OK, I'm a little confused now. According to the factory sticker, my truck came with a HF35 axle, which would indicate a H190 differential. Physically looking at the diff, it has a removable 8 bolt cover, which indicates a C200! Of course the ID tag is long gone! I'm going to assume a C200, unless I find out otherwise. Any help confirming this is appreciated. 97HB, 2.4l, 5spd. King cab RWD
