C200 exploded view
Brynjar
Car: Patrol
Help!
I've got Nissan Patrol MQ160 axles on my offroad comp.car and i'm looking for an exploded view of the front axle outers. Can't find it anywhere..
I desperately need to build a new front axle, i have a bunch of parts and an empty housing så i just need to know what goes where.
Any help would be appreciated.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Brynjar
Car: Patrol
Thanks.
That helps with the diff. I'm also trying to find the same type of drawing for the hubs/knuckles.
Towncivilian
Could you give me your VIN? Perhaps I can pull up something in the FAST system.
Brynjar
Car: Patrol
Appreciate it but i'm afraid i can't. All i have are the axles which i've been told are from a early 80's Patrol 3.3 Turbo Diesel.
They're under a comp car with a Zuki frame, Volvo engine/trans and a Zuki crawler case. :D
Towncivilian
Ah, interesting.
Probably the closest thing you'll find for a hub/knuckle diagram is in the 1989 D21 Hardbody FSM in the front axle/suspension section. I'd suggest to right click -> save as - it's a 112MB PDF file.
Brynjar
Car: Patrol
Thanks again.
I blew up my ARB and beat the snot out of my axle housing som i'm going to have to rebuild the whole thing by the end of the month.
I've only worked on Danas before so having a nice view of what i'm dealing with is a big help.
Towncivilian
You may want to check out the Nissan Pathfinder Off Road Association forum as well. More than likely, someone over there has owned a Patrol and has done something similar to what you plan. :)
