Post by 95SENTRA » https://forums.nicoclub.com/95sentra-u67675.html Sat Jun 09, 2007 5:13 am
Post by UK-P11GT » https://forums.nicoclub.com/uk-p11gt-u67424.html Sat Jun 09, 2007 5:49 am
cv joints are all pretty much the same, the number of teeth on the joint vary whether ur car has ABS or not, with abs I think its 44 teeth without I think its 42 so if your havin a serious problem gettin the joint back into the hub splines then that explains it, but a pair or circlip pliers to squeeze the circlip inside the joint and hopefully the joint will come off with a few taps of a hammer. the new 1 just pushes on till u hear the circlip click into place in its recess in the drive shaft.95SENTRA wrote:What tools will I need to change the C.V. Joints on my 95 Nissan Sentra with an automatic transmission ??? I have changed C.V. Joints on other cars , but not a Nissan any info would be great , Thanks , Brad .
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
