C-MOD Grill Installation
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
juice316
Hello Everyone,
I just purchased a C-MOD Grill for my Versa and got it painted the same color as my vehicle. Now I have a couple of questions.
1) What is the easiest/best way to install this?
2) I want to use the Nissan Emblem from my OEM grill but see that the emblem is embedded in the OEM grill and that would take a lot of work to embed it in the C-MOD Grill. Any suggestions?
Thanks in advance for your replies.
C-mod
You can simply drill holes on the C-mod grille and install it with stock plastic clips, you can also remove the OEM Nissan emblem from the stock grille and attach to our grille with strong double sided tape or glue.
Return to “Versa Technical Discussions”
