C.L.R. in tank?
omarb45
Car: 1994 q45 t/c black on black
Ok found out why my g50 keeps killing fuel pumps.after I replaced fuel pump and got baby running,couldnt figure out why she ran poor even after taking her out for some high speed driving.Seems like she has more than 1 injector out now,so she sat for a few days.then I went to start her and nothing...again.Well,I proceeded to pull pump and..seen that the o-ring was slimmy and falling apart.wtf!!!now Im pissed.how is this possible?So my very loving and thoughtfull girlfriend comes home and i tell her the good news even acuse the gas station of having bad gas when..She says "i wonder did that c.l.r.had anything to do with it".hm come again.well her brother suggested to poor some in tank to clean out fuel system even swore by it,saying thats what he put in his acura.So i asked how much went in to car.she replied half a bottle!!!!Now Im feeling like Ike,an she's looking like Tina!!So gents,Iknow ill need another pump.(3rd)new injectors.o-ring.drain fuel tank.fuel filter.anything else?Besides repoing her set of keys?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I'm surprised the rest of your fuel system isn't in shambles, too!!!!
I'd definitely pull the tank and clean it well.
omarb45
not sure what to look for any ideas?
Q451990
Hopefully someone with more knowledge about chemistry will chime in soon. If it killed anything, it's your injectors. The fact that the o-ring was bad is scary for your injector o-rings.
I would remove the tank and steam clean it and dry it with alcohol. Perhaps flush the pump with good gasoline outside of the car and see if it can be salvaged. Replace the filter and rubber hoses. Not sure on the rest of it.
Again, someone who understands chemistry should be able to help more. Lord knows what that stuff did to your aluminum engine components...
Try to find out exactly what flavor of CLR they used before you dump the girlfriend and kill her brother!
Heath
omarb45
Thanks Heath.She said it was a grey bottle,Ill go to home depo to look at it.there web site doesnt really say much or what it would do to metal.Talked to her mad scientist brother he said he told her about an ounce not half a bottle.Either way im boiling.Why she would listen to him I dont know,I sold him my very nice v6 tempo and its now barely running but of course,he has to have the big speakers in it.dammit!can the pump be taken apart?Yea I know the o-rings are shot dont need to hydro her.I did peep into tank it still looks new,pump has some sort of powder on it like a light coat of rust maybe.so come out come out where ever you are super posters help me out.I promise when i get rich I wont forget a bout you.
Wow.
This one gets some sort of prize.
Here's what got dumped in the tank:
Component CAS# OSHA HAZARD % by Weight1. Water 7732-18-5 NO 81-892. Lactic Acid 79-33-4 YES 8-123. Lauryldimethyl Hydroxysultaine 13197-76-7 N0 2-54. Propylene Glycol Normal Butyl Ether 5131-66-8 YES 1-2
It's very acidic (low pH), which is why it dissolves bases (such as calcium deposits). Also quite corrosive... Can't be good for aluminum.
Replace the pump, drain the tank, disconnect the fuel lines at the engine, blow them out with compressed air, and refill with good fuel and run it for a while.
omarb45
thanks AZ.sounds good but,my concern would be for o-rings on injectors.I havent drained tank but I did fill up with fresh gas when I put my old fuel pump in,car bounced pretty hard.She tried to smooth out after running her hard.Like I said earlier,the tank o-ring was in bad shape litterally fell apart in my hands in slimmy pieces.Will do what Heath said about flushing pump with gas,sucks its less than a year old.Will pull fuel lines and blow out as well as new filter.Are there any warning signs before you hydro an engine? Appreciate you guys helping out.If i didnt like tomatoes so much,Id pour the gas on her prized plant.
I'd like to think the injector seals would survive, they're not as "exposed"....
Hydrolock shouldn't be a concern since you're not dumping fuel.
omarb45
Before this happened.she ran very good no bouncing smooth idle.occasional dead spot in throtle below 2000rpm but no other running issues.Now its bouncing worse than when I changed number 8 injector.I was thinking about opening one of the fuel pumps,is there anything in them to frankenstien into one pump?Thanks for quick responses.
I'm thinking you might be better off just replacing it with an aftermarket one.
A Walbro 255 can be had for $89, and it's cheap insurance.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Yeah, I put a walbro in my Maxima when its pump went bad and haven't looked back. Cheaper than OEM but still great quality.
Q451990
I wouldn't risk the injector o-rings. Once a lower one leaks the fuel pump is powerful enough to hydrolock things pretty quickly. They certainly come into contact with more fuel more than the fuel sender to tank o-ring.
I know this isn't an easy fix, but wow... this is a real mess.
Heath
omarb45
Is the walbro just drop in and forget it?Or do i have to do something special?
omarb45
S basicly i have to do a plennum pull.
omarb45
AZhitman wrote:I'm thinking you might be better off just replacing it with an aftermarket one.
Thats n external pump right?
No, it's in-tank.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
1. Punch your former girlfriends brother in the face HARD.
2. Dump your girlfriend.
3. get a COMPLETE new or used fuel system. I mean everthing that was exposed to CLR.
Wow this tops the NICO dump post list, Even the "How to change a tire" topic and the "My car won't start" topic
omarb45
Would love to but he is only 18.Been with her for 15 years,just wont let her move in.Now as in entire fuel system,is that.. pump,injectors,filter and hoses or is there something else?Do have 1 question not related to this.I had a pioneer 2din dvd put in dash,but never changed out bose in back,just disconected amps.will speakers damage head unit in any way?Because...I was so happy when i got her running I forgot to adjust stereo levels back down after re-conecting battery,and a real bass heavy track came on.Ready basiclly went out.I think someone cursed me.....So what prize do i win?
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
omarb45 wrote:Is the walbro just drop in and forget it?Or do i have to do something special?
It's basically a direct replacement for the stock pump. You will have to splice the power harness, as it's different than stock, but that's a simple matter.
omarb45
Ok looked on there site n noticed there pumps dont come with any warranty...Well with my luck thats the least of my problems.
Infinitiguy19
omarb45 wrote:Would love to but he is only 18. Been with her for 15 years.
18 is legal to have sex with, should be legal enough to mess someone up too. 15 years though, DAMN thats a loooooong time.
omarb45 wrote:Now as in entire fuel system,is that.. pump,injectors,filter and hoses or is there something else?
Was the car started?
If so then replace all the fuel lines running under the car and the rubber hose in the engine bay that connectects to the fuel filter. Then replace every rubber fuel hose under plenum and fuel rails, injectors and O-rings.
So your looking at $3000 worth of damage just for parts, But were in sue happy America.
omarb45 wrote:Ok looked on there site n noticed there pumps dont come with any warranty...Well with my luck thats the least of my problems.
Shouldn't be an issue. Half the cas on this site run a Walbro, especially the heavily-modded ones.
omarb45
Well i guess there will b another q sitting n scrap yard.
Infinitiguy19
Part-out before it hits the scrap yards?
omarb45
possible.When I finally get tired of looking out window and seeing her look so sad,or when I get n my girls rather cluttered honda and I actually like it.But untill then what you guys need?black on black.seats have no rips or cracks just usual stress marks.t/c heated seats,no dents all lights good,all electronics work.well except dvd,150000miles.have 4 18inch tires bought at firestone n Texas before I came back about 2000 miles on em.no burns in car dash n interior look new.um throw some numbers out there for what you guys might want.
mtzgr777
Car: 1996 Infiniti Q45 143k Silver/Black
omarb45 wrote:possible.When I finally get tired of looking out window and seeing her look so sad,or when I get n my girls rather cluttered honda and I actually like it.But untill then what you guys need?black on black.seats have no rips or cracks just usual stress marks.t/c heated seats,no dents all lights good,all electronics work.well except dvd,150000miles.have 4 18inch tires bought at firestone n Texas before I came back about 2000 miles on em.no burns in car dash n interior look new.um throw some numbers out there for what you guys might want.
I GOT FIRST DIBS ON YOUR THROTTLE POSITION SENSOR! Let me know when your ready to take it out...I need it ASAP.
Infinitiguy19
To bad its a 1994 and not a late 1995 or 1996 Infiniti Q45.
