heybilly wrote:Ok brought the '95 J30 to infiniti and was told id need to replace the 2 knock sensors... also found out this will take about 10 hours and a few infiniti dollars to get done... now my question is what resistance does the normal knock sensor put out so i can just place a resistor in the path to the ecu so the comp thinks its working fine? and anyone know how to find the sensors and trace the wires back to the ecu?
heybilly wrote:On that note i think ill um try the DIY... can anyone explain to me what is involved to remove and replace both knock sensors?
VimyJ wrote:"The two knock sensors are attached to the cylinder block and sense engine knocking conditions." - From the service manual
However, only one knock sensor is shown in an illustration and only one is indicated on the circuit diagram.The ECM flashes "code 23" but the check engine light will not come on when there is a problem.
Professor_Mike wrote:Unless your skills are fairly high, replacing the knock sensors on a J is very involved due to the pulley for the timing belt bolts to the lower plenum.
