Sopdadope »
https://forums.nicoclub.com/sopdadope-u303.html
Tue Nov 26, 2002 6:23 pm
Hey burn504, welcome to the club!
To give you a short answer: no. There are no preouts at all, just a factory harness. If it's anything like the BOSE systems I've worked on in the past, you cannot add an auxiliary appliances (for the lack of a better word) ie EQ's, amps, to the headunit by way of splicing.
There are amps built-in to each individual speaker and resistance is 2ohms and not 4ohms standad on almost all aftermarket devices.
You can add a sub to your system by splicing the signal from any one of the speakers and supplying it to one of those sub packages especially designed for this application but that's about all you can do with that BOSE system.
If you want to upgrade, you need to revamp the entire system h/u, speakers and all.
That's a sweeet car you have and I wish ya the best of luck!
