bypassing amp on s14
sdubz
well my front speakers stopped working, so i assumed that the amp went dead. Instead of replacing the amp, i decided to get a new headunit (alpine), which i planned to use without the external amps. To check everything out, i plugged in the deck using a wire harness, and the deck turned on fine. However, after bypassing the amp using these (http://www.240sx.org/faq/artic...s.htm) instructions, i plugged everything back in and now the deck doesnt even turn on. As well, i noticed that the digital clock on the speedo displays really faded numbers.
I tried checking the fuses in the fuse box under the hood, and they all look ok. I also searched a whole bunch of forums, and it seems like this has happened to a several people, but with no solution posted.
Anyone know what i did wrong?? thanks in advance
allthrottlenobottle
Car: 91 s13
not too sure but the article said he used a seperate power,maybe you have your ground wire from the deck to the dimmer pwr wire? seen that cause probs
sorry not too much help
sdubz
hmm actually that was not necessary...i just had a blown fuse under my kicker panel.everything works now:)
allthrottlenobottle
Car: 91 s13
glad that was it ,sometimes wiring problems just go on and on!
