bypass valve vs BOV
A home for 1983–1989 300ZX owners!
SSSDesign
got a 86 300ZX with single turbo. want to put a BOV on it. do i have to remove the bypass valve or can i leave it on there and just add the BOV, and how could i do it?
Zwicked
Car: 1990 300 ZX tt, 1990 240SX
Seeing as no one has replied, I'll just post what I know. From what I have read, the recirculation type valve is better than a BOV for a couple reasons.
-with a BOV you lose some of the metered air that's in the intake tract-a recirc valve is better because it does exactly as it says, it puts the air back into the intake side of the turbo and you don't stall out the turbine wheel
I think if you left both on, the recirc valve would become sort of useless as you'd be bleeding off the pressure to the outside world so there wouldn't be anything to recirculate.
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
I moved this to the classic Z forum (which includes Z31's) so that you'll get a little more action on it.
flubturbo300z
Car: 87 nissan 300zx turbo 5spd
you do have to remove the bypass valve to put a bov on. go to the hardware store and buy pvc pipe to thread in and the cap it
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
SSSDesign wrote:got a 86 300ZX with single turbo. want to put a BOV on it. do i have to remove the bypass valve or can i leave it on there and just add the BOV, and how could i do it?
You don't have to remove it. But why are you adding a BOV in the first place?
FoxFire
Car: 90 vg30eT 240SX, s12 vg30e
a recirculator valve is the same thing as a bov except the recirculator valve returns the air back to the system so it doesnt run super rich on deaccell
you planning on running straight turbo(no filter) with a map based system? if not dont change the recirc valve. just add more recirc's if your having problems with compressor surge
AZ-ZBum
FoxFire wrote:a recirculator valve is the same thing as a bov except the recirculator valve returns the air back to the system so it doesnt run super rich on deaccell
Stock Z31 doesn't have a BOV or recirc valve. It does have a pop off valve (or emergency relief valve) on the intake plenum that opens at about 8psi in case the wastegate of the turbo fails and tries to overboost.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
and if you want to tun more boost you can plug the stock pop pff valve, but before you turn up the boost an intercooler will keep things a bit safer
Return to “300ZX (Z31) Forum”
