Jberger »
https://forums.nicoclub.com/jberger-u226.html
Fri May 23, 2003 5:46 am
In the Amsoil config, the oil is filtered by the regular filter, just like the factory setup. Then about 5% of that filtered oil volume is then sent over to the secondary filter for processing. The secondary filter then performs additional filtration and returns the oil to the system.
So only a small portion is filtered at a time, and all the large particles are already filtered out by the regular filter.
The secondary filter is larger than the average OEM filter and does not have to be changed on 3,500 intervals.
I've got no problem changing engine oil regularly, but if it's possible to further reduce the wear factor, I'm all for it. Heck, that's why I use Synthetic oil, it's not mandated by the factory, but I believe it offers better protection for the incremental costs.
Dennis, I'm suprised your not very interested in bypass filtration, I'd have thought you'd be one of the first to try it out. Just for the advantages in filtration of particles, not the extended oil life economics.
