bypass emergency brakes
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
terrell0884
Car: 07 Infiniti G35 Sedan
22" Niche Pulse
BC Coilover
SPC Camber Arms
Rear Window Spoiler
2010 Conversion (in process NOW)
do anybody know where I can order a bypass to use my screen in my 2007 G35 sedan w/o navi as a monitor? I've placed a video on and it works with e-brakes down and connections in middle console AUX inputs. Just need the bypass
timmy0257
Car: 08 Infiniti G35 Journey 5AT
-R2C Intake
-interior LEDs w/ tag lights
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Future Mods include GT-Spec strut bar & more.
terrell0884 wrote:do anybody know where I can order a bypass to use my screen in my 2007 G35 sedan w/o navi as a monitor? I've placed a video on and it works with e-brakes down and connections in middle console AUX inputs. Just need the bypass
there are a few walkthroughs on here.
you will want to locate the AV control unit and identify the e-brake wire and VSS (vehicle speed sensor)
Refer to the FSMs for your vehicle and choose the one for the AV.
look at page 59. wire # 106 is the ebrake and #107 is the VSS.
typically, you terminate the VSS and ground the harness end of the ebrake. but do all of this at your own risk.
remember to plug everything else back in correctly.
terrell0884
22" Niche Pulse
BC Coilover
SPC Camber Arms
Rear Window Spoiler
Hey Timmy would this require me to remove the center console? ive done it one on a coupe for removal of navigation limits while driving. could you provide me a link where instructions are detailed...thanks again
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
terrell0884 wrote:Hey Timmy would this require me to remove the center console? ive done it one on a coupe for removal of navigation limits while driving. could you provide me a link where instructions are detailed...thanks again
how-to-bypass-video-on-a-2008-g35-t331450.html
it is in the FAQs at the top of the forum.
kepe in mind this is for the 08 G. I pulled your FSM to give you the wire numbers. just make sure you review that and know what you are doing.
center console does not have to come out. look at your FSM on how to remove AV Unit. check the exploded view.
Return to “G35 and G37 Interior, Exterior and Audio”
