nexien »
https://forums.nicoclub.com/nexien-u188199.html
Sat Oct 15, 2011 5:59 pm
yeah i install it with a swith so basically when i want to watch video while in motion just press the swith however if i want to go back to navigation it takes few seconds to get the signal once it pick up the signal its fine.
so this mod is safe then...
well after working on that mod.. i then expererienced my telescoping make grinding noise when i shut off and get out of the vehicle... however when i adjust it up and down everything seems to work fine but when i adjust back and forth it rattled and make funny grinding noise,... is this the motor is seized? i mean up and down works fine... is this needs lubrication? i mean its still under guarantee. i will bring in for the dealer to have look at it but since i did this mod the wire from the switch is ran across and under the steering and the switch is right beside the lane departure button slot. i wonder if this will affect the guarantee since the wire being ran like that. or shall i disconnect it or keep like that?
