Buzzing sound from Fuel Pump when stepping on the gas pedal.
fm300zx
Car: 1995 300ZX N/A 207,589miles (as of Feb 03,2011)
I have noticed it today while I was driving my car,that when I'm pressing on the gas pedal I can hear a buzzing sound on my back seat. So I stopped the car on a parking lot and rev the car on and off to observe/listen where is the sound coming from. It does sound like it's coming from where the fuel pump is located. I know it's normal to hear a buzzing sound when you first turn your key to on or when you start the car, but then that buzzing sound usually goes away. Is it a sign my that fuel pump is getting ready to die? or is it clogged? any help or idea will be appreciated.thanks!
Chattzx
Car: 90 Z32
Some fuel pumps are nosier than others. I wouldn't worry about it, mine has done it for a while now but only when I turn on/off the car.
Stadsport
Car: 1990 Nissan 300ZX Twin Turbo 5-speed
I've heard that it's an indication of a fuel pump going out, but I've also had a brand new OEM fuel pump do it on really hot days... I wouldn't worry about it too much unless it does it ALL THE TIME.
txQ45
Car: 91 300zx TT
Check your Fuel Pump controller.. open it up and see if any of the amps are burnt or if anything is melting .. If so you need that
fm300zx
Thanks for the replies. The buzzing sound seemed to quit doing it the next day when I drove the car.
