buzzing noise
kernan240sx
Car: 89 240sx
Is it normal to have a buzzing noise near the injectors when the engine is turned to assesory mode?
r3v_v3ng3
Car: 91 fastback ka-t
how do you know its the injectors? do you have someone to turn the key to the acc and you listen in the engine compartment? if your inside its mostlikely your fuel pump
dstrcto
Car: '92 240sx SE Coupe - '95 Acura Integra SE
I can hear this noise too, I had my stereo on for a while so I couldn't hear it (it drained the battery). It's definitely in the engine bay, I just can't figure out where it's coming from...
kernan240sx
Car: 89 240sx
This isnt the fuel pump, its something else. I turned my car to assesory mode to see if my injectors were leaking and there was a buzzing coming from the area around the injectors.
dstrcto
Ok, so now the car won't do it anymore, but...
When I had the car sitting there and it WAS doing it, I pushed on the throttle and it stopped.
Then another time, it was silent and when I pushed on the throttle it made the noise.
I'm not sure what this means, cuz I didn't have anyone else around to look at it while I pushed the throttle. (yes I know I could have done it by hand, but it wouldn't have been the same)
