eds13 wrote:no there the cheap radioshack rcas. I ran the rcas and the remote down through the center, the power wire down the pasengers side fo the car. the buzz is only though the sub. oh and for the record i have a deh-6500 pioneer head unit.(not sure if it's in my sig)
The RCAs *may* be a problem, but more then likely they are not.
Also, running the RCAs on the opposite side of the vehicle from the power is unneccessary. You have to remember that you're working with a DC system. So the power that goes through that line has to return somehow. Unless you pulled a wire from the negative pole to your amplifier, like I do, then your cars body is used as the negative connection. So where in the vehicle can you run your RCAs so tha tyou arn't near the body? Hint: You CAN'T. So don't worry about it
