CopyChief »
https://forums.nicoclub.com/copychief-u57560.html
Fri Feb 15, 2008 5:48 am
A couple of things seem to affect this. First, make sure the dimmer switch (left side of the steering wheel on the dash) is turned all the way up and locked. The dimmer can cause some interference. Also, try a different cable if you have one. If you're using your iPod's headphone jack, turn the volume up as far as you can without distorting the sound, then adjust the volume on your stereo very loud. Better yet, try to use a dock-to-miniplug connector, which will give you the best sound (although you won't be able to charge it at the same time.)
