buzzing noise from near fuel tank
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
hey guys,
i parked in the garage today to do some work on the truck... and about once a minute after shutting the truck off it would make this wierd buzzing noise from the rear fuel tank area. It did this about 10 times and hasnt done it since now. I got it on the camera... what is this? Fuel tank relay stuck or something ??
heres a clip:http://www.youtube.com/watch?v=l4ItGDau5D0
cheers for any input...
Marko
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Have you tried pulling the pump fuse while it's making that noise to see if it affects the pump?
Dj Hentai
Car: 95 Nissan Hardbody
it's coming from a small black plastic piece (the name escapes me at the moment, I think it's a pressure valve.) on the frame rail near the fuel tank. Replace it and the buzz will go away. I did this about a hundred times when I worked for Nissan.
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
would you be able to figure the part out from here?http://www.courtesyparts.com/h....html
i am not seeing any pressure valve.. maybe im blind :P is it the check valve?
Dj Hentai
Yep the Check Valve - 17330
