onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Wed May 02, 2007 8:30 am
I'd probably personally lean more toward a 235/40R18, but 245/40R18 should be okay.
Each tire sits slightly different, so keep that in mind. It has mostly to do w/ the actual tread width, sidewall protectors, etc.
For example, I ran 225 on an 8" rim w/ bridgestone re750's and it has a thick sidewall protector so it covered up the rim pretty good & even bulged just a little. I ran 235 Federal ss595 on a 7" rim and it bulges a little, but relatively less than the bridgestone (considering it's only a 7" rim). Hope that makes sense. A tire like falken azenis 215/615 run one size large (i.e. a 225 looks like most other tires' 245) because of the sidewall.
