7K sounds pretty good..i paid 6.5k for my 97 base with 82k miles on it about a year ago. Auto too ;(...
Check Carfax. Get the unlimited reports for a month. It's a good deal and you can do everyone a favor by reporting their vins on here
When you testdrive it take it on the highway up to at least 70mph. See how smooth it rides at all speeds.
Drive by a wall or tunnel with your windows down & radio off..it'll reflect any odd sounds.
Check tire wear. If wear is uneven between driver & passenger side tires you prolly have alignment issues, with possible suspension problems(like mine had, a bent LCA). The inner tread of the tires may be worn more, which is normal for RWD's.
