Mr. Music »
https://forums.nicoclub.com/mr-music-u82550.html
Wed Feb 20, 2008 7:19 am
Yeah, being in the same time zone helps.There won't be a problem with the lugs, that mainly happens with thicker spacers; so no need to worry with a 5mm spacer. As far as a problem for the drop, it depends on how wide the tire is. The stock tires on the Altima Coupe are 215 mm wide, if you go with something like a 245, then you might have a problem. Something you can always consider is getting a narrower tire and having it stretched to fit the rim, but you won't need to do that. (Stretching the tire will give you a little more room to play with. For instance, if you are running a 9" wide rim, and put on a 235 tire, its going to be a little stretched, and the extra space might just be enough to give you the clearance needed.) Now, your tires are 225/45/18, and I'm going to assume that your rim is 18X8. They will sit 5mm further out than stock with the 45mm offset, 10mm further out than stock with a 5mm spacer, and 12mm further out than stock with a 7mm spacer. So, with out a spacer, you won't have a problem, with a 5mm spacer, you probably won't have a problem, and with a 7mm spacer, you might be rubbing a little since the tire will be about 1/2 an inch further out than stock. Like I said before, your best bet would be to install the rims and springs, then see how much space you have between the outer edge of the tire and the inner edge of the fender. The guys at the shop should be able to accurately tell you if you will have an issue with a spacer or not. (By the way, a +38mm offset is the essentially the same as a +45mm with a 7mm spacer)
