Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Feb 10, 2009 8:41 am
When you first buy any used car older than 3 years, do a total liquid analysis. Examine every fluid by dropping a sample on to a white paper towel and side by side compare the drop with a drop of brand new fluid.
Any visible difference in color saturation [intensity] is very suspect.
Every liguid in vehicle cost less than $100 to replace without labor.
Rear diff, ATF, engine oil, coolant, brake fluid, power steering, ac compressor oil*, even washer fluid.
Start out your ownership with everything brand new.
* the ac compressor has 8 ounces of oil which becomes acidic eventually and wears the seals inside compressor and eats the evap/condenser solder fins from inside. Whether it is better to wait until $2-2,500 in repairs are needed or spend the $200 to service and change oil is up to owners.Spending $200 now to defer another year or 2 is always cost effective.
