flyboy367 wrote:oh and if you can post links to the org stuff. for some reason my ip is banned there after my first post and i cant get back in
can't post link to the org here or i'll get a ban but check out jwt aka
http://www.jimwolftechnology.com and no offense to THT but no matter what motor it'll always benefit from upgraded cams and on a n/a eng there's not much point in getting a wideband o2 and spending a bunch on a controller because your stock o2's are supposed to give you as close to ideal a/f as possible. udps are a scam because your power isn't taken away as much by a couple extra pounds as by the power steering pump - look into getting a toyota mr2 pump which is hydro-electric and doesn't run off the crank.
the tb mod - do you do it yourself and how or do you give it to a machine shop?
