Buying new turbo
driftedsilvia
Car: 93 Fastback
I got an s13 blacktop blowing oil inside..Can some one please guide me to purchasiung a new turbo..Are the t3/t4 ar50 on ebay any good?Should I trust anything without "Garrett" on it?I got a budget of arround $500 and like to purchase something i can boost harder in the future....What else can I afford?
CoupedUp
Car: 1993 Coupe
If you are wanting to buy a T3 Flanged manifold and the lines for the setup and a turbo. I hope that doesnt include all $500 dollars.
Garret T3/T04E 50 Trim .63 A/R: $619
http://cheapturbo.stores.yahoo....html
Garret T3/T04E 50 Trim .48 A/R: $619
I would reccomend one of those and if you only have strictly 500 I'd save, if youre wanting to buy a T3 setup on $500 dollars. Id reccomend buying a used T25/T28 Turbo rather than cheaping out a T3 setup.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
See if you can find a used low milage S15 turbo, generally go for around 500
Morph
Car: 91 Sr Powered Coupe
If you only have 500 then you dont have enough. If you are replacing the turbo then to make it much easier on your self you would be smart to get new ss lines. You can still reuse the old hardlines but you will need to bend them to fit the new turbo. In the case with the s15 you will need a s15 oil return tube. You could modify the one on the s13 but IMO its a poor place to go cheap and starve the turbo of oil and kill your new turbo for a 25 dollar part. Then you will need new piping, or cut your old piping to fit the new turbo. So unless you find 1 hell of a deal i dont think you are going to have enough cash.
Also what other mods do you have? FMIC? Boost controler? Exhaust? injectors??
All in all i'll agree with Onizuka get a s15 turbo when you have some more cash to play with.
Onizuka
I'd be more worried about the engine itself being oil starved if the turbo oil return pops off. When I put an s15 turbo on my sr I just slotted the bolt holes on the oil return fitting and used some new reinforced rubber tubing back to the block. Never had any leaking or problems with 14,000+ miles of driving/racing on that setup.
But yeah, there is still some modification in addition that needs to be done with the S15 turbo, Im sure there is alot of threads that have this all detailed.
driftedsilvia
Car: 93 Fastback
Thanks alot for your input...Do you guys know of any reliable source where I can get a used turbo.I had a bad exp with used turbos wich is what in the car right know and has been blowing oil inside and out since day one"i didnt install it and im not ever letting any one else touch my car again"Maybe a place where i can send mine out te get rebuild and upgrade..
