bstd240 »
https://forums.nicoclub.com/bstd240-u1259.html
Thu Sep 12, 2002 6:31 am
sorry,i didn't make myself clear, i'm buying it from a local importer, but he doesn't have any clips in stock, so one will be ordered and will come in within the next 3-4 weeks(apparently). This is the thing, if the clip/engine were here i would have a leakdown and compression test done prior to taking it( he says compression/leakdown tests are done in japan), and check out the rest of the engine as well, but i will be giving a deposit(50%), prior to ordering it. i don't want to have to put just as much as i paid for the engine just to get it running the way it should (i.e. any parts needed for a properintall...mafs/cas/canister, etc) so should i include everything in writing (every item), and what should they be, and should they be replaced at no charge?
Thanks againJohn David
