Hey, I've read the threads here about bar and plate vs. tube and fin--and there seems to be quite a bit of misinformation saying how much more efficient/superior/more expensive bar and plate is versus tube and fin.
However, the turbo expert, Corky Bell himself makes no such distinction. Quoted directly from the FAQ section of his site:
"Does one style core cool better than another?No, almost no difference. With three decades of testing intercooler’s, we have found no appreciable difference between any core style or manufacturer. Keep in mind, that the merit of a core is it’s efficiency versus its internal drag characteristics. When sized for a tolerable flow loss, virtually all cores will produce essentially the same efficiency results. Perhaps a core with slightly less flow area per linear inch, or one with longer tubes, will need perhaps 5% more tubes to equal the best of intercooler’s with regard to flow loss and efficiency. Not a very important difference."
And...
"What are the variations in core construction used in intercoolers?The variations are in the style of manufacture of the core material. A “Bar and Plate”-Style Core is made by brazing up a layered structure of flat plates separated by small rectangular spacers. A “Tube and Flange”-Style Core is created by extending a series of tubes through a header flange and brazing the assembly together. For heavy duty applications, pressure spikes up to 250 psig and rugged environments, ”Solid Extruded Tube”-Style Cores are available."
Anyway, it seems that on places like ebay there are an abundance of bar and plate intercoolers for pretty cheap prices. However, these are all no-name brand intercoolers sold by no-name companies. But, they are rather cheap (almost always under $300). And, none of these companies state the efficiency of the intercooler OR the pressure drop--which I think is a pretty important thing to know when buying one.
I'll be getting one for my birthday (feb 7) and want to know what you guys prefer from PERSONAL experience as to what you think would be the best intercooler--either a cheap, no-name brand one from ebay that I know nothing about that is bar and plate, or a billet tube-and-fin design air/air intercooler from JGStools.com that costs $399.
http://www.jgstools.com/turbo/index2.html
What appeals to me so much about the JGS intercooler is that it's the perfect size for my application (2.75 x 8 x 30" overall), and I'm having trouble finding intercoolers that are SHORT enough horizontally/vertically and slim enough for thickness.
I REALLY need an efficient intercooler with very little pressure drop and I don't want to put a piece of crap on my car--I don't like how I'll increase lag by finally intercooling so I want to make sure the factors that can be controlled---efficiency and pressure drop---will be optimized.
Also--what seems to be more durable against stones/road debris--tube and fin or bar and plate?
So basically--cheap, abundant bar-and-plate no-name intercoolers on ebay or billet tube-and-fin whose exact specs I know available from JGS?!?
Thanks for any input....
