Buying Aftermarket Online, Reputable Websites?
timothy.kelley86
Car: 2008 M35
So CPJ gave some great advice on how to fix an alignment problem I am having and I cannot wait to rip my car apart (or at least make a hell of an attempt). However, I need parts! Does anyone have a go to website that they use to buy high quality aftermarket parts? eBay is too cheap, dealerships are too expensive, wheres the balance (autozone, napa, car parts international)?
Wangtang408
Car: 2006 Infiniti M35
Bump for CPJ! :dblthumb:
timothy.kelley86
Car: 2008 M35
Bump again for DIY!!!!
Wangtang408
what kind of parts are you looking for?
Larz
Car: 2019 Q70-L RWD
I have purchased items on Ebay but you're right - you MUST be careful. Circle Infiniti (dealership in NJ I believe) sells OEM parts on Ebay at good prices - got my spark plugs, belts, and some other parts there. Also there is a place called Infinitipartsonline. It depends on which parts you need.
timothy.kelley86
Car: 2008 M35
Looking for front and rear sway bar links and front outer tie rods... Hopefully these won't cost too much and will be easy to replace...
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
timothy.kelley86 wrote:Looking for front and rear sway bar links and front outer tie rods... Hopefully these won't cost too much and will be easy to replace...
shouldn't be expensive...you can also try AutoParts Warehouse to start (get pricing from there and then compare to InfinitipartsUSA)
08 M35
http://www.autopartswarehouse.com/searc ... omponents)
06 M45
seymore4
Car: 2012 M56
Professional UPREV tuner
I've had good experiences with rockauto.com
BigBlueX
Car: 2011 G37X
seymore4 wrote:I've had good experiences with rockauto.com
Seymore: Can you PM with regards to UpRev options and pricing? There isn't a PM link under your contact area. Thanks
