qship96 wrote:Expect a minimum of $5,000 in hidden worn out parts- not including anything cosmetic.
Qship is not far off the mark. My 92Q that I bought for $1 (not a typo... one dollar) 3 1/2 years ago from a generous former NICO member and drove home 300 miles with no issues has cost me about $7500 to keep in tip top condition.
- Thermostat, alternator belt $250
- Leaking fuel hose under plenum $220
- Michelin pilot sport tires $1130
- Replace all 4 rotors and brakes $700
- Hood struts, radiator cap $57
- Battery $105
- Replace 2 fuel injectors under intake $715 (PO had replaced all 8 with remanufactured FI. I'm using new FI)
- Replace rack & pinion assy, 2 hoses custom made since they were discontinued $1750
- Replace FI #1 (did this myself) $117
- Replace AC compressor and convert to R-124 since compressor and R-12 freon not available $1175
- Lots of oil and filter changes and numerous other incidentals not listed.
I love my Q and she runs great but I can't afford to keep it after retirement in January. I'll be lucky to get $1500 for it and will go back to my 94 Toyota truck as the daily driver. If you're on a budget and can't afford repairs I wouldn't recommend a Q45 of any model year. If you want a great car that's fun to drive and don't mind spending lots of $$ to keep it running, buy it.
BTW... The fuel odors are either the PO didn't replace the swelled fuel pump o-ring when he replaced the FP and/or there's stripped or missing bolts securing the FP assembly to the gas tank. You need to remove the rear seat and the upper parcel deck to get to the fuel pump. The window issue is broken regulators which is the cable assembly that raises and lowers the window.
Good luck with your purchase.
