Re037 wrote:150 across the board on just 4 rotations. im pretty happy with it. 30 day warranty on block and heads only. time to order me tt fuel pump and wiring harness. should i buy new injectors?
Was this cold or after the engine is warm? I would still be weary, those numbers can be, well lets say, altered. The warranty is total BS, very few people get the engine in the car and running good enough to drive around in 30 days, unless you have a ton of time or you take it to a shop, and still that will take a few weeks.
Im not trying to push you away from TT'ing your car, it is a blast when the turbos kick in, and do not regret it in any way. It is just an expensive venture, and swaps normally cost in the range of 6k-10k. I would personally wait until you find someone parting with a TT engine that can prove with you there the compression or even rebuild one yourself.
I do have a JDM engine, but this was bought from a running car that got wrecked, the guy was even able to start it up and I was able to hear it and compression test it before he pulled it out. If anything go on projectZ32, look up Zdreams, pm him. He might be able to get you a deal on a TT engine or even point you in the right direction. Coz is a good guy, I have never had issues with him and has always helped me out. Some others have on this forum, but this is my .02 about him. He used to get his clips through Pitstop, which s what I heard, which is where his shop used to be at in Phoenix, I had a few bad experiences with Pitstop and would not trust them. Some of the guys had good experience on the project Z site, so maybe ask around if Coz does get through them.
Whatever you decide to do, just make sure you do your homework and ask questions, A LOT OF QUESTIONS. We are all here to help.
