Buying a sr trans(rwd)
BLKSTAR
Car: S13 vert/coupe
I'm buying a transmission tomorrow and I just want to make sure that i'm getting the right trans. How can you tell the difference between a ka trans and an sr trans?
funigui
Car: I HAD a 1991 240sx coupe. woked NA motor. ran like 14.5 ish. blew it up @ 140 after an ECU reflash.
the bellhousing, i know a red top sr trans has almost corners on top and fit sizt 17 bolts
the ka housing is more rounded and fits 14ns.
also if it is a ka trans, u can just swap bellhousings from the old sr trans u have to the ka trans and it works fine.
